Can someone remind me how to get the tab that lifts up, I believe it is the lifter arm back down in drawer 3/4 on an IR600 so the drawer will slide back in?
IR600 Drawer 3/4 lifter arm
It is on the front of the paper feed assembly itself. The easiest way I can recommend is to pull the paper feed assembly out the right side of the copier. This will drop the lifter, and while you have it in your hands, examine how the lifter mechanism works and what releases it..."Once a King, always a King, but once a Knight is enough!"
Thanks, I'll try that, I thought I was overlooking something really simple. I appreciate your help.Comment
