Havent done this in a while and forgot how to make blk for copy default on touch screen. Thanks for replys.
ir 3200 default
Set the copy screen to as you want to set the default i.e. 2 sided options, colour options
then...
{*) > Copy Settings > Down to Pg 2 > Standard Settings > Store
It will show what you have set the settings to, Tap "Yes", the "Done" till your back to the copy screen
Good LuckComment
there are cleaning solutions for these drums/ u can use a lint free cloth to wipe, caution>u may scratch drum ot leave hand oil prints on surface
On FORUM main page go to>
Technical Forums>
Copier Technical Discussion
select Manuf> {CANON}
select Post New Thread
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
