iR2570Ci problem. E020-01a2
  • crcb2b
    • Feb 2010
    • 21
    [Error Code] iR2570Ci problem. E020-01a2
    The total counter: 127000. 30000 copies before new developing assy was replaced eith the same error, the 020-01A2 after that gone. Now, the same error. What guys you will suggest for me? The ARM sensor was cleaned and sensor above the drum unit cleaned too.
  • teckat
    • 16092
    place a service call for a CANON trained tech
    • vj200729
      print mate
      • 81
      you have checked any toner catridge empty
      • neonic
        Have had this problem on a few machines ir3100 range usually poor dev bias connections on rear of turret, if your lucky just bent and 20min fix, if unlucky snapped and "put the kettle on, i'm gonna be here a while"
        if you have small fingers you can just about feel the leaf springs through the cut outs in the rear of the turret and bend them back slightly towards the rear of the machine (don't blame me if YOU snap them off )
        if they are snapped or missing then its turret removal time..
        good luck.
        • teckat
          • 16092
          make sure ITB is locked up in position
          how is the Drum ??/ what % of Color are u outputting- Normal page coverage is 6%>8% coverage on LTR sz
          • crcb2b
            • Feb 2010
            • 21
            What are you mean ITB locked ? However, I consider strange sound during Warming Up before the copier show the error.
            The drum is almost new. Just 13000 left. I replaced it few monthes ago by myself. Fuser too. The toner coverage is normal for basic office documents, however full of yellow toner's dust I noticed on the other developing assy's and under developing assy's carousel. The error's description says that the problem color is yellow, SNGL parameter is the same or above of number 960. Something above 1014 I saw it in service mode.
            • crcb2b
              • Feb 2010
              • 21
              good luck.
              What are you mean the word "rear of turret" ?
              • crcb2b
                • Feb 2010
                • 21
                Give me please a phone number. I am in a Europe.
                • crcb2b
                  • Feb 2010
                  • 21
                  cheked. Few days ago the customer replaced magenta and yellow cartridges. Others are near full.
                  • teckat
                    • 16092
                    u have a yellow issue/overtone problem
                    = find a Canon service company in your area
                    how do u find a business where u are located ?? do u have a Business Directory ?
                    Look Here in Canon Europe
                    http://www.canon-europe.com/Support/...or/index.aspx#
