IR C3220 ImagePass C1 PRINT tab gone
  • 2new2no
    • Dec 2007
    • 48
    Hi, I am now learning the C 3200 & c3220, my first two Canon copiers in my collecting (I have 3 toshiba 4511 yuck)
    Print Tab on the c3320 is not longer there after playing in service mode, I must of change wrong setting.
    IMP-CONT is set to 3 so I do not know what else to look for. I saw another post about this on a different forum but they never address the answer.
  • charm5496
    • 2387
    I would first try changing the IMG-CNT to 0 and cycle the power. After that go back in and change it back to a 3
    also verify that Verify that UI-EXT or UI-EPRNT is set to '1' in level 2.
    I would get yourself a manual before you go playing around in service mode!!!!
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Print P-PRINT from another copier and compare values.Also check in manual.
      Something is different with D CON ore M CON.
      • 2new2no
        • Dec 2007
        • 48
        I learn by doing and figuring things out on my own. I do have the SM. I found the setting by switching items on and off. But thank you very much for your suggestions.
        Option / Body / CNTR-DSP = 1
        • teckat
          • 16083
          In Level 2
          COPIER>OPTION>USER
          CNT-DSP (Used to select whether to display serial number when counter check key is
          pressed.)
          0: Display serial number.
          1: Donโ€™t display serial number.
          • 2new2no
            • Dec 2007
            • 48
            Level 1
            Settings 0: The external controller icon is displayed on the control panel of
            the copier
            [Factory default/After RAM clear]
            (When the color image server is connected.)
            1: The control panel of the copier becomes nondisplay mode
            (When the control panel-mounted external controller is
            connected.)
            Actually on my unit 0= not displayed 1=displayed
            • teckat
              • 16083
              Level 1
              the copier
              connected.)
              READ what it says/ there are two different options being talked about
              color image server
              is connected
              that has nothing to do with display of Print Tab
              once u install a imagePass C1/C2 the Print tab is displayed
