LPR in Canon printers
  • lincolngp
    • Jun 2025
    Hi All,
    I need send files directly to printer using LPR command, option duplex.
    If anybody can help me.
    thanks
    Lincoln
  • teckat
    • 16083
    Originally posted by lincolngp
    Hi All,
    thanks
    Lincoln
    what model machine ?????
    Printing LPR to the iR Series
    setting up an LPR port for the imageRUNNER-iR Series, do the following: 1. For the Name or address of server providing lpd put in the IP address of the imageRUNNER.
    2. You also need to specify a print queue for the Name of printer or print queue on that server. There are three print queues available (be sure to use only capital letters):
    LP The machine prints according to its spool settings (normally use LP as a print queue).
    SPOOL The machine prints only after spooling a print job on the hard disk regardless of its spool settings.
    DIRECT The machine prints without spooling a print job on the hard disk regardless of its spool settings.
    In Windows Vista
    , the LPQ and LPR commands are not available by default. These commands are part of Printer Services, but you must enable the LPR Port Monitor to use them.
    1. Click the Start Menu.
    2. Select 'Settings'.
    3. Click on 'Control Panel'.
    4. Double click on the 'Programs and Features' applet.
    5.Click the 'Turn Windows features on or off' link.
    6. Expand 'Print Services' and look for 'LPR Print Monitor'. Check the box for 'LPR Print Monitor' to enable it. Click OK.
    7.Enabling the feature may take some time. Wait until the task has been completed.
    8. Reboot the computer when prompted to.
    • lincolngp
      Model ImagePRESS 1135.
      Thanks.
      • teckat
        • 16083
        did u change the port to LPR type ?
        • lincolngp
          No, i dont change de port.
          I use this command: lpr -S 10.0.0.10 -P PDF -J TESTE.PDF "c:\teste.pdf", but i need define the duplex print mode.
          • Fer
            • Nov 2009
            • 267
            I don't if there is an lpr command to enable duplex print, maybe u need to PS command inside the PDF document.
            If u don't need to switch between single or double sided u can enable duplex in "printer settings"
            • lincolngp
              So, i nedd switch, becouse exist various applications.
              My work is Variable Data Print...
              In equipaments Xerox do it.
              • charm5496
                • 2387
                which model Xerox are you trying to compare the 1135 to and which printing option do you have on the Canon?
                If your xerox is older I can see that working the way you are describing. You can't really compare old technology to the new...
                Also what version of windows are you trying to set this up on? That info will be needed as well.
                • lincolngp
                  Sorry, I did not want to compare equipment.
                  The model is Xerox E180.
                  • teckat
                    • 16083
                    Are u using VISTA ??
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Try (from a command prompt): lpr -S 10.0.0.10 -P lp c:\teste.pdf -o DuplexNoTumble -o 1
                      It's case sensitive, and the "o"s are the letter "o", not "zero"
                      • lincolngp
                        No, Windows XP.
                        I can print using the command:
                        but must be printed in DUPLEX.
                        • lincolngp
                          Not accept.
                          • mrfixit51
                            Lead Service Technician
                            • Oct 2008
                            • 1975
                            I am curious, just for my own education,,, why do you need to print to this device using a command string, as opposed to using the print driver??? Is this printing from linux or mainframe??
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              OK, try this then: lpr 10.0.0.10 -P lp c:\teste.pdf -o DuplexNoTumble
                              The "o 1" switch sets binary mode; perhaps it's not needed with the duplex option set.
                              I just tried this with a Ricoh machine in my office (I'm at home now), and the job definitely did print, but I'm not there to see if duplex worked.
                              (Your Canon machine does have PostScript in it, yes?)
