iPRC1+ Banding line issue
  • pga
    • Jul 2009
    • 67
    [Misc] iPRC1+ Banding line issue
    Dear all,
    Good day. Any ideas to resolve the banding lines issue on c1+? Currently my customer upgrade their c1 machine to c1+,they encountered c1+ banding line issues more obvious than c1. We can easily to see when print PG type 5 or midtone color.
    I tried to change ITB unit, drum unit, 2nd transfer unit and ITB drive motor but no improvement at all. Any ideas? is it can be solve?
  • charm5496
    • 2387
    without seeing samples it will bifficult to troubleshoot on this machine. But with the list of parts you have replaced I would check the drive assemblies...not just the motors. Start with the ITB and drum drive. If the meter count is high the gears are probably worn.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      Originally posted by pga
      Dear all,
      I dont wont to scare you but we have seven c1+ machines and all have the same problem
      like yours.All modifications cant make better machine.When you print half tone see
      dark lines.
      • teckat
        • 16083
        Dear all,
        banding has been an issue on these models from the start
        / some clients don't even notice
        post some pics of single color pg5's
        • pga
          • Jul 2009
          • 67
          yes. normally we won't let customer see PG type 5 but they can try print any files in 40-50% midtone and all banding lines appear. The Drum/ITB Drive ass'y already changed even is new machine. The system firmware got upgrade to latest but yet no solve.
          Some of my customers very concern on it and they may did compared with C1 printout.
          I wonder why c1 machine not obvious on banding issue but c1+ very obvious on it.
          i tot c1+ will be more better and improved from c1....but.....sad...
          anymore advice?
          • teckat
            • 16083
            anymore advice?
            Customer is printing COLOR at 40/50% ! how much paper coverage are u talking about ? if it is over 10% coverage on letter , they should have purchased a imagePress 6000
            When u print a PG5 with all 4colors, do u see a rainbow banding effect ???
            • Ingranaggio_rotto
              • Oct 2010
              • 275
              In some machines the problem is obvious, in other less...
              It's an limit of this printer engine......
