c5185 with H1 print server. not network printing
  • shawnhenson
    • Sep 2010
    • 16
    we just picked up a c5185 from a off lease dealer...
    I have had 3220's and 3200's and know my way around the c1 c2 and z3000 fiery. (pretty much the same things)
    this H1 I cant not get access to it. does anyone know the default IP for it?
    I have (while trying to get some kind of network printing) bypassed the h1 and used a network cable to the router. changed the controller in the copier setup from 3 to 0 and the printer gets a IP.
    I can get to the copier thru the remote ui and see everything. make it print out reports from the copier but still can not print from any computer.
    the computers do see it as a printer with the IP address and I install the c5185 drivers. go to print and nothing not even a green processing light, and the comptuers come up with a error on printing.
    I connect a USB cable and try it that way.. I get further and get a processing data light for 1 second and then nothing.
    what am I missing here?
  • charm5496
    • 2387
    since your machine has the H1 rip on it you can not print directly to the 5180. There are no other print options installed on it therefore your print jobs are just going to crash.
    If your H1 is password protected try Fiery.1 (case sensative) if that does not work you may have to get the system software reloaded.
    Good luck.
    • shawnhenson
      • Sep 2010
      • 16
      is there a way to use another print server ? I have a z3000 and a c2 here
      • teckat
        • 16083
        ColorPASS-GX100
        Color Network Printer Unit-H1
        this is all the options
        Good Read on H1>>
        imagePass H1 SG.pdf
        • shawnhenson
          • Sep 2010
          • 16
          Originally posted by teckat
          ColorPASS-GX100
          Good Read on H1>>
          [ATTACH]7234[/ATTACH]
          Thank you!!! going to print it on the 3220 tomorrow at work.
          How can i test to see if the h1 server actually has the software installed?
          if it isnt installed would it explain why i cant see the h1 on the network (scanned ) and when going to the print tab on the 5180 to check the status/settings it just doesnt do anything
          where can i get a h1 ISO from?
          • teckat
            • 16083
            make sure the H1 Interface cable is in good working order/ make sure u are using the Crossover cable in correct spot
            there is no ISO for image Pass H1- In fact Canon no longer produces ISO Firmware for the CLC's/imageRunners
            when H1 is plugged in an printer is powered up / look at the small LED window on H1 / if u see FF,E3 u have an issue- read that H1 Guide
            SST System Software file is for use with the Service Support Tool (SST), and the
            USB System Software is for use with a USB Flash Drive. The direction is to eliminate the process of
            imaging a CD-ROM from an ISO image
            and also, to facilitate flashing with a USB Flash Drive.
            HI software is pre-installed at factory- u should have received a two System Software CD's part 1 & 2 with the HI
            if u do not have them, u will need to call a Canon Authorized dealer for a service call on H1
            • shawnhenson
              • Sep 2010
              • 16
              what I get is a 00 on the h1. the c1 and c2 i have 00 on those when i boot the other machines. Ill look at the cd's and see what I have. thank you all for your help so far.
              • charm5496
                • 2387
                on the side of the H1 there are two LED's if the machine and the fiery are communicating properly those LED's should go through a series of codes and eventually end up at '00' If you are getting an 'FF' your firmware needs to be reloaded. If they do not come on you either have a connection issue with the machine or the H1 is having an electrical issue.
                • teckat
                  • 16083
                  00 IS GOOD/ now go from there/ make sure your COPIER>OPTION>INT-FACE>IMG-CONT IS set to 3/ when u set it ,power off printer/ N' power back on / check your Printer set up on Printer Tab
                  • shawnhenson
                    • Sep 2010
                    • 16
                    done and still can not access the printer thru the network.
                    when i do a network scan I can not see the h1 at all.
                    was there a default ip address on the h1's from the factory ?
                    • Herrmann
                      • Jan 2006
                      • 792
                      hmm.. we need a starting point
                      please print out a config page and post it here
                      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                      • teckat
                        • 16083
                        Make sure that u do not have a duplicate IP address within the same network
                        For imagePASS C2/D1/E1/G1/H1/J1 use Color Network Scan-gear Version 2.0 or higher.
                        Do U See the Printer Tab on control panel ????
                        go back in COPIER>OPTION>INT-FACE>IMG-CONT -
                        set it back to 0 hit ok-turn off printer with shut down method on panel -flip power switch off/
                        turn printer back on -go back to COPIER>OPTION>INT-FACE>IMG-CONT- set it to 3-
                        repeat the shutdown method-
                        turn back on- go to Printer tab/ re-input your Network settings- remember password is Fiery.1 if prompted
                        • fchu5959
                          Field Engineer
                          • Jun 2010
                          • 100
                          if we just start from the beginning.....
                          When you picked up the c5185 from your dealer was it running ok with the H1 attached??
                          Is it an irc5185 or clc5185??
