E0005-0000
  • Jetbus
    • 8
    [Error Code] E0005-0000
    Can't clear this code. Have replaced web and set both counters to zero, also set the error clear. Can any one help me with this trouble code.
  • Brian8506
    • 1664
    What model machine
    • Jetbus
      • 8
      E0005-0000
      The Error code is on a iR7086
      • watson
        • Sep 2009
        • 64
        Are you sure you are not mistaking the web code for the finisher communication code. If so power the finisher and copier in correct sequence.
        • Jetbus
          • 8
          E0005
          Thank You so much for the tip.
          I have already returned to the machine and confirmed that it indeed was a E0500 error and reset it. The interesting thing is that there was a E0005 error as well because the web was out. So i guess I got lost in all the 5's and 0's. So once again Thank-You for the response to my error.
