canon gp 335 hard disk formated
  • popo
    • Mar 2009
    • 30
    hi my client have formated the hard disk off his canon gp 335 can you help me restore the data now he can't print
    can you help me to restore this data and what are the steps
    thank you for your help
  • killerah
    Re: canon gp 335 hard disk formated
    Hello!
    Have the same problem as your client.
    Did you manage to help him? How?
    Thank you!
      • 16083
      Originally posted by killerah
      Hello!
      Thank you!
      GP335
      The machine may be upgraded in either of the following two ways:
      • By replacing the DIMM on the image processor PCB.
      • By updating the DIMM contents through downloading from a computer.
      The DIMM (flash ROM) used in the machine comes in two types; both types are mounted on
      the image processor PCB. Figure 14-701 shows a view in which the IP small cover has been
      removed:
      • DIMM for the IP-CPU
      4 MB: bottom of 2-layer slot
      1 MB: top of 2-layer slot
      • DC-CPU DIMM (1 MB)
      1. Before Starting the Work
      Obtain the following:
      • PC to which the downloading tool (service tool) has been installed.
      • Bi-Centronics cable (with an IEEE 1284 Standard-compliant marking)
      2. Downloading
      a. Connection
      • Check to make sure that the communication memory lamp is off.
      1) Turn off the machine's main power switch; then, disconnect the power plug, and disconnect the modular cable (telephone).
      2) Open the front door, and open the connector cover for downloading.
      3) Connect the machine to the PC with a bi- Centronics cable.
      • Make sure that the PC is off.
      • Connect the 25-pin connector of the cable to the PC, and 36-pin connector to the machine.
      4) Slide the switch to LOAD. (location>upper right hand corner)
      5) Turn on the PC, and start the downloading tool.
      6) Connect the machine's power plug to the power outlet, and turn on the main power
      switch.
      b. Downloading
      1) Select 'To Main Menu' in response to the start-up message of the downloading tool.
      2) Select 'Next' under the Download/Upload.
      3) Click the model and PCB for downloading.
      IP: DIMM for the IP-CPU
      DC-CON: DIMM for the DC-CPU
      4) Start upgrading the flash ROM following the instructions on the PC screen.
      5) When downloading is done, operate as follows to turn off the PC:OK-> To Main Menu -> End Tool -> End
      c. After Downloading
      1) Turn off the machine's main power switch, and disconnect the power plug.
      2) Disconnect the bi-Centronics cable from the PC and the machine.
      3) Slide the download switch to COPY.
      4) Close the connector cover, and close the front door.
      5) If the machine is equipped with fax functions, connect the modular cable.
      6) Turn on the main power switch.
      7) Start service mode, and check the ROM version.
      COPIER> DISPLAY>VERSION
