Canon IR 6000 Tray #3 Jammed
  • ybnews
    • Oct 2008
    • 94
    Was making booklets feeding from tray #3 (universal, changeable paper sizes)
    with guides set at LTR R position. The tray ran out of paper so I pushed the button to drop the tray and open. Tray would not slide back. It was hanging up on something. After removing the tray I see a flat, brass colored plate at the bottom center on the left side is in the raised position instead of all the way to the bottom so I cannot slide the tray back in. How can I get that plate to drop to the lower position so that the tray can slide back in?
    I tried turning off and unpluging the machine then with all the doors & trays open turned it back on hoping the thing would re-set to the correct home position.
    NO joy. Any other suggestions? I need to complete an 800 booklet run.
    Thanks,
    Dana Lewis
  • charm5496
    • 2387
    push and hold the white actuator that releases the cassette when it is in the machine. This should allow it to drop back down.
    • kuby
      • Oct 2007
      • 1396
      Ditto on pushing the white actuator.
      • ybnews
        • Oct 2008
        • 94
        Here's what I have to do for now,
        Completely remove draw #1 so I have access to #3.
        Then while pushing the release button on draw 3,
        I reach in and push down so that the paper casette drops all the way to the bottom. Aparently the drop down plate is hanging up on something and needs a little push What a P.I.T.A!
        • ybnews
          • Oct 2008
          • 94
          I think I fixed it.
          I sprayed some WD/40 where the drop down plate pivots and on the mechanism behind the white cassette release button. Lifted the drop down plate up & down a few times while holding the button in to work it in. Seems ok for now
          • teckat
            • 16083
            Originally posted by ybnews
            I think I fixed it.
            MacGyver , would be proud
