i need to use scan but my screen doesn't appear option of scan network. but i tried to open in function mode * 2 8 but found nowhere to open its function. Pls if anybody know how to open it. thank in advance.
how to open scan gear of 4570 in the service mode
* 2 8 * 2 COPIER > OPTION >USER NW-SCAN Enabling or disabling the network scan function
2
<Setting range>
0: Network scan function disabled [Default]
1: Network scan function enabled
Notes:
Not changeable for anything in Japan
Always 1 for PSPCL outside Japan
Changeable for other outside Japan -
Hi,
Level2 > COPIER > OPTION > USER > NW-SCAN
<Setting range>
Notes:
Good luck!Hardworking people are not present. Simply many it is boring to idle.Comment
This adjustment is normally for the IR2200-IR5000 seriesLast edited by SCREWTAPE; 12-03-2010, 12:23 AM.Comment
I had a customer some years ago who bought a ton of iR3570s with Universal Send who wanted to disable TWAIN scanning, and it was on by default.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Is whether or not to display the extended screen of the operating section
<Setting range> 0: Do not display 1: Display [Default](iR2270/2870/3570/4570series,iR2230/2830/3530/4530series)
The machine needs to be a network printer in order to the scan feature.Comment
