Canon C2620 Washed out looking copies/prints.
  • Jude
    • Oct 2009
    • 256
    I inherited this one from one of my clients and need to get the quality of print again. Looks like a washed ot transfer or something. Mach has 62K on the total meter.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    We need to see some sample of the problem to assist you properly... 62k is really low mileage.
    • Jezzer
      • Oct 2010
      • 10
      I suspect that process area has been opened before the RHS door, this can cause the transfer plate on the ITB unit bend back on itself as it is still in contact with transfer spring on end of transfer roller unit.
      Open RHS door check to see if brass plate is visible on ITB , should be able to bend back with small screwdriver.Good luck.
      • teckat
        • 16083
        Best advise, if u are not a tech. - place a service call , for a Canon experienced Tech.
        in Long Island call 516.877.9100
        while your at it , get a service contract, your initial service call & product inspection will be deducted from it - it will prevent headaches &
        aggravation
