Canon PC 740 - Not working after tray jamming
  • genuine_jalali
    • Aug 2025
    [Jamming] Canon PC 740 - Not working after tray jamming
    Hi there!
    My copier machine was working fine a few days ago but once the tray jammed and was not able to come out. But the machine was still working when I used to insert the paper from the side paper slot. Today, I somehow pulled the tray out found that some part of the machine was lying on the tray which was previously jamming it. The image of the part is attached. After this, my machine is not working properly. Whenever I try to copy it doesn't respoond, it stays idle...even if I add paper from the side slot it doesn't take it fully in and shows the red/orange symbol (i think the symbol is of paper jam)
    please help me...is this due to the deattachment of this part? how do i fix it back? any idea with pictures...wud be grateful
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    l think you have broken the vertical path roller paper sensor try controller ..this parts witness the presence of paper insider cassette ..please take other photo's because this is not very clear
    BEST TECHNICIAN . NICE PEOPLE .
    • Brian8506
      • 1665
      That part is what locks the tray in place. It is attached to the cassette handle with a spring and the handle is most likely broken. It should work without it but the tray may wander out. Your paper jam light may mean there actually is a jam. Check the path and the lower right door. Otherwise, you may need service
      • genuine_jalali
        I'm sorry I have @MP camera...the quality isn't good but I'm attaching more pictures. The picture of the roller wheel is also there in close up... please try to resolve this problem..thanks
        • genuine_jalali
          i'll check it and reply ...please stay in touch..thanks
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            hi friend jalali ..l think you should be have the sm to following your problems ...well tell me you have it or no ..if no contacted me at my email : mecanographe@gmail.com
            • genuine_jalali
              Hi friend, Sorry i didn't get you...what's sm?
              • RichardKem
                Re: Canon PC 740 - Not working after tray jamming
                My PC740 also has a jammed tray and still works on the 'bypass' tray. It is an old machine but has done great service. Any ideas how to open the tray without causing more damage? Thanks
