Canon IR3245 part number help???
  • ragajungle
    • Jul 2025
    If anyone has a parts book for a Canon ir 3245 could you please look up a part number for either the op panel assy or just the screen (The back light is out on half) and I don't have the parts book....
    FYI the 3235/3245 op panel is different than 3570/4570
    -thanks
    Fm3-7262-000 - CONTROL PANEL ASSEMBLY - EUR
    FM3-7261-000 - CONTROL PANEL ASSEMBLY EXCEPT JP,EUR
    FL3-0489-000 - LCD CONTROL PANEL UNIT
    • Canuck
      Tech Specialist
      • 1713
      You need the Inverter PCB Assembly. There is a new improved one out...FM4-6690-010. That will fix it. It has a jumper plug on it and you might have to move the jumper. I've replaced 3 or 4 of them for this problem
      • ragajungle
        Canuck, Skynet Thanks for the replies.
        Skynet: "FM3-7261-000 - CONTROL PANEL ASSEMBLY EXCEPT JP,EUR" - This would be the US model no?
        Canuck: I am also ordering one of these "FM4-6690-010" to try the fix. Thanks for the help!
        • Canuck
          Tech Specialist
          • 1713
          You don't need the console...expensive waste of money. The inverter will fix it....
