After the installation of a new machine is shown CODE E-748-2000. There is a strange sound from the HDD. Suspect the failure of HDD.Any suggestions?Thanks for the help.
Yes, e-support says replace the HDD. Kind of a strange code for a new machine. Since it is new contact the place you purchased it from as it will be under warranty and not cost you anything to have it fixed.
Go in and check the HDD Connections/ In fact remove back panel & check all PCB's & connections & Main Controller
