error e677-5803
  • blu3sky
    • Jul 2010
    • 25
    [Misc] error e677-5803
    i have canon ir 5000
    every i shut down my machine and then i turn on again, it will be displaying the text "e677-5803 PDL No RIP Hardware"
    please give me a solution
  • teckat
    • 16083
    what were u trying to do before Error ??
    E677-5803 PDL No RIP Hardware. The RIP1 board is not installed or not working properly.
    For the imageRUNNER 5000 with the old main controller, check to see if the RIP Board is installed next to the parallel port. If there is not a RIP board installed, then install the Network Printer Kit-A1 (sales item # F61-8502-000). Since the A1 kit has been discontinued...if you get this error and you are installing the Network Printer Kit-A2 in the 5000 (old main controller) then you must replace and install the new main controller. You can only install the Network Printer Kit-A2 in an iR5000 with the new main controller.
    Error :
    E677 Error Code, imageRUNNER 5000 / 6000
    There are many causes depending upon the sub-code, the 4 digit code after E677, for example E677-5803.
    Here is a list of errors which can be displayed on the LCD control and are not in the service manual.
    E677-5801 PDL Accelerator
    E677-5802 PDL Initialize Error
    E677-5802 PDL Service Call
    Please contact Canon Hardware Service Support for more information or view the other related entries titled E677-5802 or Flashing an imageRUNNER 5000 / 6000 with Version 60.04 Main Controller Software Causes the Copier to Fail to Boot (E677-5802).
    Or
    After installing system software, an error code E677-5803 is indicated.
    Make sure that you are loading the correct software into the machine.
    • 5000 (Copier)
    • 5000N (NETWORK)
    If copier system software was loaded into a network machine, FORMAT and reload with network system software.
    If network system software was loaded into a stand alone machine, then FORMAT and reload copier system software.
    • blu3sky
      • Jul 2010
      • 25
      i didn't do anything. I'm just buy the used goods and it happen
      • teckat
        • 16083
        You know the Old Saying
        Be Careful What U Wish For !!!!!!!!!!!!!!!!!!
        • blu3sky
          • Jul 2010
          • 25
          thank you... teckat
