Canon C1 imagepress
  • mark921
    • Dec 2010
    • 110
    [Misc] Canon C1 imagepress
    Just curious...what do you guys feel the recommended monthly volume should be for this unit?
  • teckat
    • 16083
    Per Canon>
    imagePRESS C1
    This is all tested at 6>8 %pct. Color coverage on Letter paper> per Copy/Print
    Canon can't even explain this below>
    Maximum Monthly Copy Volume / Optimum Performance
    imagePRESS C1
    Suggested maximum monthly print/copy volume =Up to 100,000 impressions
    Optimum performance range (prints/copies per month)= Approximately 3,000 to 35,000 impressions
    Note: The maximum monthly volume (print/copy) represents the maximum
    number of pages the machine can produce within a one-month period (based
    upon letter size paper). However, the device should not be used to produce
    this or a greater volume on a consistent monthly basis
    • mark921
      • Dec 2010
      • 110
      Thanks Teckat. What, in your experience, is the MTBF on this unit?
      • teckat
        • 16083
        It all depends on what the customer is Printing/Pct. of Color/Paper type/ & Volume
        This model is made to be used & not abused /
        Remember even though it has the word Press in it - a Press it is Not
        It is a COPY Machine-
        • mark921
          • Dec 2010
          • 110
          Got it. I always like to cut the manufacturers recommended volume in half (at least). How do you feel it performs on cover stock (100# gloss cover, 12 pt C2S)?
          • teckat
            • 16083
            Read pdf >
            imagePRESS.pdf
            • mark921
              • Dec 2010
              • 110
              Teckat, i thank you for the prompt answers! Clearly, you're a pro!
              • charm5496
                • 2387
                keep in mind that the gloss cover stock is going to slow this machine down significantly. We have a publication house that prints nothing but covers from one of these on a 110 lb gloss cover 12x18 around 35K a month. The units does require a little more attention than normal, but the customer knows that downtime is going to happen and the time to clean and repair is not going to be short either.
