ir6570 - cleaning web roller
  • y_us1982
    • Aug 2025
    anybody know how the correct position when replacing a new cleaning web roller.
  • teckat
    • 16083
    Removing the Fixing Web
    1) Open the front cover.
    2) Slide out the fixing feeding unit.
    3) Remove the center screw , and detach the fixing upper cover .
    4)Remove the 2 screws -one on each end , and open the web unit .
    5) Push the web feed roller and the web take up roller toward the rear, and detach the fixing web
    6) Clean the surface of the silicone oil tray.
    1) Wind the web [2] around the fixing take up roller [1] 2 to 3 times. (While winding it at the front, make sure that the arm guide plate [3] is outside of the takeup roller. Also, at this time, check to make sure that the area of contact with the roller is impregnated with oil.)
    Check to make sure that the fixing web is not a skew and is free of slack [A] and wrinkling.
    Also, check to make sure that the fixing web is wound in the following direction and orientation:
    2) When you have fitted the fixing web, move the
    plunger [1] of the solenoid in the direction of the
    arrow until the fixing web is free of slack.
    - When you have replaced the fixing web, be sure to reset
    the counter reading to '0' using the following service mode items:
    COPIER>COUNTER>MISC>FIX-WEB
    COPIER>COUNTER>DRBL-1>FIX-WEB
    • y_us1982
      when on ir8500, is the position of web roller same like ir6570?
      • teckat
        • 16083
        now u need info on a 8500 ???
        Are u a tech ????
        or End user ?
