Re: iR4570 - fixing film jam
i have the same problem in the fixing unit can you help me please. I really apreciate
Guest replied -
Guest repliedRe: iR4570 - fixing film jam
My IR 3045 Do the same
the Paper stops in the middle of the fixing unit. when i removed the paper it is folded like an accordion.
I tried all 4 trays and did the same thing
Paper Orientation: Portait
I did notice that when i place the paper in Landscape it works much better but will jam after couple of copies and some of the copies have fold in the middle. so it goes out of the machine shorter than other copies.
Error: 1017, 0202, 0102, 0201
All sensors checked, - not sticking
right door flapper check
Fixing unit rolls fine
Paper: SUB20/70gsmLeave a comment:
The black film is the same, the thermal capacity of the heating units is different, along with the 3-4 wire connector. I have always wondered why they could not get along with a single model and just manage the temp needs in software...Leave a comment:
Today I conducted a test of the ir2270 fixing film assembly in an ir3570 copier, it worked fine for at least 4000 copies don't worry paper well used, only copy jobs where paper would be used in future.
Well the fixing film failed it began to shred and tear. I did this checkmto see if there is a difference in both fixing units or if the were interchangeable by changing off the power connector ends.
Fortunately the unit did not last as long as the ones that are recommended.
LinuxxpwinLeave a comment:
Temperature is the issue with the paper curl, not pressure. Increasing pressure would induce more curl I believe...Leave a comment:
Regarding the 70gsm paper, jam in duplex mode. in my experiance increase a little bit the pressure roller tension will solve this problem.Leave a comment:
COPIER > OPTION > BODY
FIX-LOW= Improving fixing at low temperature
Note: Valid for iR3570/3570F/4570/4570F only
<Setting range>
0: OFF [Default], 1: Low-temperature fixing improvement mode ON
Controlling the Power Supply in Response to Low Temperature
In a low temperature environment, the heater is supplied with power before the fixing film is driven so as to soften the grease applied to the fixing film. The mechanism of control is as follows:
If the temperature of the fixing film detected by the thermistor is lower than a specific level, the heater is supplied with power for a specific period of time before a normal start-up mechanism is initiated.
If the temperature of the fixing film detected by the thermistor is higher than a specific level, the normal start-up mechanism is imitated.
In a low temperature environment, the feeding timing is changed according to the
temperature detected by the environment sensor so as to enhance the fixing capability. The details are described below.
When the environment sensor detection temperature is 13 deg C or less, the feeding timing is delayed by 5000 msec.
In thick paper mode, the feeding timing is not changed even if the environment sensor detection temperature is 13 deg C or less.Leave a comment:
If you research further here, that topic has been discussed a great deal, search on 0107 jamming. There is indeed paper curl, induced by the fuser, mostly occurs in damp weather. There is a procedure to reduce this problem, the gist of the fix is lowering the fuser temp in service mode...Leave a comment:
Guest repliedyr film is original or compatible ?Leave a comment:
Guest repliedseems like the duplex guide don't have any problem. the single side print was ok, but after the paper across the duplex unit to print the second side, the paper will jam at the drum unit before reach the fixing assy. the paper will look like a curve and it goes right inside the drum made it stuck. i wonder if the paper get too hot when it first across the fixing assy make the paper get a curve.Leave a comment:
Product : imageRUNNER 2230 / 2270 / 2830 / 2870 / 3530 / 3570 / 4570 Title : Where is the CL6 Duplex Clutch Located in the iR3570 & iR4570?
Where is the CL6 duplex clutch located in the iR3570 & iR4570?
Answer :
There is not a CL6 duplex clutch in the iR3530, iR3570 & iR4570. This is not meant to be a trick question. It is easy to misinterpret the documentation regarding this clutch in the parts Catalog. The following parts catalog pages show the confusion. Neither page indicates which Main Drive Assembly is for which machines. (Note: The words in red are not listed in the printed catalog.)
If you are having a duplex drive problem on an iR3530, 3570 and iR4570 look to the M10 Duplex Drive Motor located on Figure 261. The M10 stepper motor is part of the Fixing Paper Delivery Drive Assembly.
Check if the Duplex Guide on the 3 Way Unit is damaged or not mounted correctly.
Duplex.jpgLeave a comment:
Guest repliedis it true that ir4570 had duplex problem when running on a4 size(70gsm)?Leave a comment:
