E 009 after installation on iRC 2020.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi !
    I have this problem: at installation of the iRC 2020 with Fax, the machine display error code E 009.
    This code appears after the device outs from stand-by.....
    Tips ?
    Thank.....
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Originally posted by Ingranaggio_rotto
    Hi !
    Tips ?
    Thank.....
    I never so IRC 2020.
    If you have IR2020 error code E 0009 do not exist.
    Probably you have user fax code:
    #0009 [Rx] recording paper has jammed or is absent
    • zoraldinho
      • Mar 2008
      • 5018
      Hi !
      Tips ?
      Thank.....
      If you have IRA2020!!
      1. Check if the Fixing Assembly is installed.
      2. Remove and reinstall the Fixing Assembly
      3. Check the gear
      4. Replace the Fixing Assembly
      5. Check the harness/connector between the DC Controller
      PCB (UN09/ J210) and the Fixing Motor (M17).
      6. Check the harness/connector between the DC Controller
      PCB (UN09/ J12) and the Fixing Pressure Release Sensor
      (PS24)
      6. Check conduction of FU1153 in the AC Driver PCB
      (UN14)
      => Replace the AC Driver PCB (UN14) in the case of
      disconnection.
      7. Replace the Fixing Motor (M17)
      8. Replace the DC Controller PCB (UN09)
      • ranjith@ast
        • Feb 2015
        • 5
        Re: E 009 after installation on iRC 2020.
        Hi !
        Tips ?
        Thank.....
        Change fixing assembly
        • zoraldinho
          • Mar 2008
          • 5018
          12-28-2010
