If a Canon IR C3100 runs out of yellow toner, shouldn't i be able to print in black?
Canon IR C3100 out of color toner
Tags: black, black and white, black toner, c3100, canon, canon ir c3100, color, color toner, copyi, lef, print, toner, yellow
Explanation is not needed if u know the color copy
process.
imageRUNNER C3100 / C6800
If black toner is still left in the machine, you can continue to print and copy in black and white. However, if the print or copy job is interrupted because cyan, yellow or magenta runs out, printing and copying is only possible in black and white for functions other than those being used for the interrupted job. If toner runs out during a job, printing of that job will resume after replacing the toner cartridge.
NO.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
set the default color to black
First, press the Auto Color Selection tab and select "Black".
Select the Additional Function Button
Select The Copy Settings Button and go to the Second Screen
Press the Standard Settings Button
Select Store ( A message will come up asking you if you wish to store this setting.)
Select "Yes" Store in Memory
Press the Done Button
Press the Done Button again in order to go out of the Additional Function Screen**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
