Canon IRC4080 e000110-0236
  • cweber0531
    • 71
    Hey Guys,
    I don't work on color machines but am helping out another tech and don't have SM. Can someone let me know what this code is including sub code. I appreciate in advance.
    North Shore
  • teckat
    • 16083
    Originally posted by cweber0531
    Hey Guys,
    North Shore
    E110-0236
    2=MAGENTA LASER UNIT ISSUE
    E110 Polygon error
    1st line: Always 0
    2nd line: Station where the error occurred (1: Y, 2: M, 3: C, 4: K)
    3rd line: Main unit status when the error occurred (0: Activating, 1: Correcting the image position, 2: Changing the speed, 3: Operating steadily)
    4th line: Polygon control status (0: Suspension, 1: FG rotation, 2: BD control 1, 3: BD control 2, 4: BD control 3, 5: BD control 4, 6: Phase locked
    First check for a pinched cable on DC1/ J203 & J206
    also check if fully seated
    RESULT IS=0xx6 An error occurred after "motor locked" was detected once.
    (1)Check whether the harness is not removed.
    (2)Replace the scanner unit.
    (3)Replace the power unit.
    (4)Replace the harness.
    (5)Replace the DC controller PCB 1 .
    CHECK HIGHLIGHTED CONNECTORS
    • Canuck
      Tech Specialist
      • 1713
      Just switch the magenta laser with one of the other colors,make adjustments(power,delay) then see if it moves to another color. If the error totally disappears,then something got reseated and you are fine. If it moved to another color,then bad laser assembly. If still errors on magenta,reseat dcon connectors,main sub-boards and connectors
