iR 2525 Fax and send report
  • Peter Sim
    • Sep 2008
    • 445
    Hai ,
    I need help.
    My iR2525 had fax and U-send option.
    Need to have fax TX report and do alot of scanning.
    Under Report setting ,if i off the TX report,both fax and scan will not print out and if i on the TX report ,it will both print out.
    Any way to only OFF the scanning report??
    Because everytime i do smb scan ,will also print out report .
    Thank you in advance.
  • teckat
    • 16083
    in some imageRunner models, there is a setting in Additional Functions > Functions Settings > Send > Common Settings > screen 2 - Communication Management Report & set Auto Print to OFF then select OK.
    U could look in RemoteUI - under Additional Fun./Settings>SMB server settings
    Do not believe that setting is available in this model !!
    For this model series there is only one parameter for a transmission report which encompasses every send operation which includes Fax, Email and Scan to File.
    TX Report
    On, For Error Only
    Report With TX Image: On, Off
    Off
    Activity Report
    Auto Print: On, Off
    Send/Receive Separate: On, Off
    Daily Activity Report Time: On, Off
    RX Report
    On, For Error Only, Off
    Fax Activity Report*1
    Auto Print: On, Off
    *1 Indicates items that are available only when the optional Super G3 Fax Board-AG1 is
    attached to the machine.
    • Peter Sim
      • Sep 2008
      • 445
      Hai teckat,
      Thank you for your reply.
      For this model ,under report setting,i can't find Send setting
      I will try to OFF the Auto print report and see what will happen.
      TX Report
      On, For Error Only
      Off
      Activity Report
      Auto Print: On, Off
      RX Report
      Auto Print: On, Off
