ir5570 print quality pooblem
  • hamdyyassin
    • 84
    my copier canon ir570 copy is ok but the print quality is very dark i cheak service mode,
    and make R.S. with no progress.
    thanks for help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    If you have copy OK and print very dark,only driver is included in this issue.
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      As Zoraldinho suggested, it is probably related to your print driver. The older versions of UFRII caused this on color ir's. Try using PCL5e, or download the latest driver from Canon.
      Another thing to check is in Additional functions-> Printer settings-> quality/density(?). 5 is default, lower makes it darker and higher makes it lighter.
