Canon ir3320i Errors
  • prasad_vari
    [Error Code] Canon ir3320i Errors
    Hi
    this is prasad,
    my machine error E602 , and another problem every time 2nd tray paper jam problem, i see tray, no paper inside,
    how to solve problem?
    plz help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Originally posted by prasad_vari
    Hi
    this is prasad,
    plz help
    Hi Prasad
    E602 is Hard disk error.Probably you must replace with new one.
    For paper jam problem check:
    1.paper format in cassette.
    2.replace paper pick ups.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      zoraldinho has both of your answers,,
      the copier thinks there is paper present in the 2nd tray when there is indeed none present, then you need to look at the paper present mechanism in that 2nd tray to find your problem. With the drawer empty, check the Choose Paper button on the op panel to see if the copier thinks there is paper present or not.
