IR 3225N
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    IR 3225N
    Helloooo friends,palls and chiefs
    Ir 3225n make interesting issue.Take a look and report please.(only serious please)
    Things I already made:
    1. new laser
    2.new drum
    3.clear DC and MN controller
    4.check all connectors
    1995_001.pdf
  • teckat
    • 16083
    1. new laser
    2.new drum
    [ATTACH]7890[/ATTACH]
    looks like a grounding issue !!!!
    check to see if registration roller is grounded
    does it happen on prints only ???
    • charm5496
      • 2387
      Have seen this on the 70 and 45 series machines where the grounding spring on the steel registration roller was not making proper contact. Reforming the ground spring on the left hand side of the registration roller; so that it properly touched the metal registration roller resolved the image fault.
      That being said the grounding tab for this unit is not in the same sopt on the registration roller shaft. It is on the non-op side of the shaft inbetween a plastic guide.
      • zoraldinho
        • Mar 2008
        • 5018
        Copy also make issue.Why do you ask.It s not logic question.What is on your mind?
        Copier is far far away,so i need some ideas before get back.
        • teckat
          • 16083
          this is what charm5496 means about GD plate
          PAPER FEEDER FRAME ASSEMBLY/ Reg.Roller
          • teckat
            • 16083
            Question is on target/ see information picture
            reason I ask is because, u can have a grounding issue off glass copies also
            • zoraldinho
              • Mar 2008
              • 5018
              This is second reply about grounding.Is this true,you gays have a lot of beers.
              • zoraldinho
                • Mar 2008
                • 5018
                [ATTACH=CONFIG]7898[/ATTACH]
                Thanks Tec.I exactly now what we talking about,but i still can t believe.Tomorrow will see.Also thanks to Charm.
                • charm5496
                  • 2387
                  not a problem. The first time I saw this issue I thought I was drunk or going cross eyed, but the solution was always the grounding tab. I have also seen a tech put a bunch of grease on it for some reason causing the issue.
                  • mrfixit51
                    Lead Service Technician
                    • Oct 2008
                    • 1975
                    I had this same issue a few years back on an iR3025, I was unaware of the grounding strap on the registration/transfer assembly. I did make sure the steel registration roller was grounded. I finally replaced the whole spring loaded front of the registration/transfer assembly, and that resolved my problem.
                    I now can see why it was fixed, I probably got a new grounding strap in that assembly.
                    • Canuck
                      Tech Specialist
                      • 1713
                      Clean the clip and reform it to mount biased against steel roll. Use CONDUCTIVE grease...thats what the black GOO on it is.
                      • mrfixit51
                        • Oct 2008
                        • 1975
                        I used the official "black goo" on my machine, on the steel registration roller. That did not resolve my problem, I replaced the entire face of the registration/transfer assembly, the one pictured by Teckat, and that finally resolved my issue.
                        • zoraldinho
                          • Mar 2008
                          • 5018
                          Thanks for response David
                          • Canuck
                            Tech Specialist
                            • 1713
                            I'm not talking about that clip. I'm talking about the one on the machine itself,rides on silver reg roll at the front when the door is open. I've never had an issue with the one on the door itself.....yet
                            • mrfixit51
                              • Oct 2008
                              • 1975
                              As I stated more than once, the steel registration roller, directly under the developer mag roller, is where I had already used the prescribed treatment of conductive grease. It did not resolve my problem. The grounding strap on the registration/transfer assembly mounted on the door evidently did.
                              It took me several visits to finally remedy my problem. I hope you do not get that opportunity ;-)
                              Stay warm up there!!
