canon c1+
  • cedarstreet
    • Jun 2010
    • 44
    canon c1+
    our canon c1+ is unable to print the p-report - technician was in yesterday to do service and found it won't print this report - simply goes to alarm mode - puzzled technician -
  • teckat
    • 16083
    When selecting P-Print in Service Mode, the P-Print will flash “Active” but no output is generated.
    Also, in the upper right of the LCD, the <SERVICE> icon will change to <ALARM>. At this point, if the control panel soft switch is cycled, the error light will flash, and the default screen will be displayed. On the bottom of the screen will now indicate “Report” and “LTR load paper.”
    to see LOAD PAPER Message/
    u must have at least Firmware ver.66.04
    Solution :
    The following conditions must be set in order to generate a P-Print:
    1) The paper source must contain one of these paper sizes, LTR, LTR-R, LGL or 11x17.
    2) Paper Type should be set to Plain.
    3) The Cassette in which the report will print from must be enabled "ON" under Drawer Eligibility.
    To view or change this setting > Additional Function > Common Settings >
    Drawer Eligibility for APS/ADS > < OTHER > < enable the cassette ON >
    power off printer/ then power on printer
    then>
    1) Go into Service Mode
    2) Hit Function
    3) Hit Misc-P
    4) Hit P-Print
    5) Hit OK
    • cedarstreet
      • Jun 2010
      • 44
      thanks for help - found that settings for the letter cassette was set for heavy thus no print - reset to plain and it printed fine - so how much to train me to work on my c1+ - canon service in our rural area consists of a guy reading a manual on site - I am an old service tech - will you train me?
      • teckat
        • 16083
        Pay for my plane fare from USA/ will also need logging-food
        best bet= get a imagePress C1 Service Manual/
        do a self learn on your own time
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          [ATTACH=CONFIG]7927[/ATTACH]
          fair enough
