Downgraded Advance firmware, sendkit gone
  • Fer
    • Nov 2009
    • 267
    I accidently downgraded (option 3 overwrite in stead of option 1 upgrade) an IR Advance 50xx from 55 to 45. Now my sendkit is gone.
    Going back tommorow to upgrade to 55 again, format if needed.
    Any advice?
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Sounds like the upgrade should take care of it. Send kit is standard so there is no license that could've been lost.
    • Canuck
      Tech Specialist
      • 1713
      And any advanced send options(encrypt,signature,etc) that require keys will remain.Even after replacing HDD. Key info stored on counter pcb.
      • charm5496
        • 2387
        this is a standard option of the device. I would get a different version and do a full overwrite of the firmware. Also make sure that the option to display the SEND option is not disabled.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Any advice?
          Probably you didn t mark t everything what you need in SST.Do you have some other missing files on copier?
          Just overwrite everything again and you be fine.
          • Fer
            • Nov 2009
            • 267
            went back today, with latest fw v55.10 upgraded with upgrade only button. Was working fine again.
