Machine running very slow and intermittently giving this code. Points to main controller pcb. Anyone else run into this code?
IRC2880 e-000240-0000
Tags: 240, code, controller, copyi, intermittently, irc, main, occur, pcb, registration roller, roller, sea, slow
Intermittently when copying or printing, the paper will stop at the registration roller and the copier will continue to cycle. Shortly after an error E240-0001/0002 will occur.
Code
Main Cause/Detail of Detection
Countermeasures
E240 ?
Error in communication of controller
Error in communication data0000
Check connector, check connection of sub PCB in the controller box, check / replace DC controller PCB / main controller PCB
There is no response when 3 sec passed since the main controller had sent the pickup request to DC controller during printing.0001
There is no response when 4 sec passed since the main controller had sent the request for image output to DC controller during printing.0002
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
