imagePRESS C1/ C1+ Minimizing Intermittent 010D Jams - REVISED
  • teckat
    • 16083
    [Jamming] imagePRESS C1/ C1+ Minimizing Intermittent 010D Jams - REVISED
    imagePRESS C1/ C1+
    there is an increase in the number of 010D jam codes
    occurring in the field. In order to help address this issue, this Technical Publication will delineate a list of items that should be checked to address this jam code.
    It is imperative that periodic maintenance be performed on the Fixing Belt Assembly on a timely basis to minimize the possibility of the Fixing Belt Assembly contributing to this issue.
    see attached Pub.
    TP08-1.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Originally posted by teckat
    imagePRESS C1/ C1+
    see attached Pub.
    [ATTACH]7940[/ATTACH]
    Thanks for the info.Viva Canon USA.We can have a lot of discussion about C1.It s slow like Gutenberg from 1935.Half tones are disaster.Repair one issue, their comes another but globally it s very good machine.
    If you have demanding customer you are dead.
    • Van Steal
      • 177
      Thanks for the info teckat..This jam code is a real pain to fix, the best result I've had is replacing the 4 pre-fuser belts. I get few months with no jams before it comes back in. I've even but a new fuser in but jammed on the first try..that was an expensive non fix
