dear tech;
are there any way to make the TEXT/PHOTO mode a little whiter from the SERVICE MODE (*2+8*).
COPIER>ADJUST>AE>AE-TBL (text density adjustment for real-time AE mode)
Use it to change the parameter for adjustment of the density correction curve (for real-time AE mode; 10 steps). Range: 0 to 9 (default: 4) A higher setting increases text density.
A lower setting decreases text density.
Thanks, always TECKAT is the first knight. the white door label says: AE = 5
Can I know a hint about the: V-cont (EPOTOFST/ VD-OFST/ DE-OFS-P/ DE-OFS-P/ DE-OFST) Blank (BLANK-T/ BLANK-B) Feeder (DOCST/ LA-SPEED)
What they do for the copied paper (hard copy). Thanks in advance.
COPIER>ADJUST<V-CONT> Adjusting the Potential Control SystemEPOTOFST=(entering offset value for potential sensor)
0 to 255 (default: 0)
COPIER>ADJUST>V-CONT>VD-OFST=(entering offset value for VD target potential for copying)
-5 to +5 (unit: 10 V; default: 0)
COPIER>ADJUST>V-CONT>VD-OFS-P=(entering offset value for VD target potential for printing)
-5 to +5 (unit: 10V; default: 0)
COPIER>ADJUST>V-CONT>DE-OFS-P=(adjusting Vdc for printing)
-50 to +50 (unit: V; default: 0)
COPIER>ADJUST>V-CONT>DE-OFST=(adjusting Vdc for copying)
-50 to +50 (default: 0)
BLANK>Adjusting the Non-Image Width
If you have cleared the RAM on the DC controller PCB, enter the value indicated on the
service label
COPIER>ADJUST<BLANK>=BLANK-T
Use it to enter the image leading edge non-image width adjustment value.
Range of adjustment 1 to 500 BLANK-B
Use it to enter the image trailing edge non-image width adjustment value. Use a PG5 TEST PRINT TO CHECK BLANKEDGE
COPIER>ADJUST>FEEDER DOCST
Use it to adjust the original leading edge registration when the ADF is selected
as the source of paper.
• A higher setting decreases the leading edge margin.
• The data will be stored on the ADF controller PCB.
Range of adjustment -10 to +10 (unit: 0.5 mm) Using the Mode
1) Make a print of the test chart, and check the position of the image.
2) Select the mode item, and change the setting to make adjustments.
3) Press the OK key.
4) Make a print of the test chart once again, and check to see the position of
the image is as indicated. LE.JPG LA-SPEED
Use it to adjust the original feed speed for ADF stream reading speed.
• A higher setting increases the speed.
Range of adjustment -30 to +30 (unit: 0.1%)
