Canon ir5570 copy problem
  • hamdyyassin
    • 84
    My copier canon ir5570 gives white copy wirth vl1t=0 when i change potential control the copy is very dark.
    the copir dpot display lpower-p=23 lpower-c= 117 primp=0 primc=0.
    thanks for help.
  • c0846
    change corona wire
    service mode > copy > Function > DPC > DPC > 1
    off/on Power
    • hamdyyassin
      • 84
      I change primary corona and HV PCB and the copy is white.
      • teckat
        • 16083
        check that - Copier>Option>Body>PO-CNT is set to 1
        run- Copier>Function>DPC>1>OK
        re-check the Potential Control harness and its associated connectors for kinks, wire ties,bent pins and proper routing.
        check DISPLAY > DPOT for the following voltages
        DPOT-K = 0V
        VL1T = 60V
        VL1M = 0V
        VL2M = 0V
        VDT = 370V
        VDM = 0V
        VL2M-P = 0v
        VL1M-P = 0V
