IR5000n Door
  • ar6565
    • 94
    IR5000n Door
    When I turn on the Ir5000n
    it shows an err (ask me to open and close the front door)
    when I open and close any door then the machine is Ready.
    Cleared R-con & Dc-con & Err
    But it still ask me to open and close the door every time I turn it on.
    How I clear that Err for ever.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Disconnect the finisher and see if the problem happens. If it does not happen with the finisher disconnected check/replace the stapler.
    • ar6565
      • 94
      Pls note the finsher isn't installed and the stapler.
      • victor_v
        • 71
        What about, at first to press a door, and then to turn the device on?
        Hardworking people are not present. Simply many it is boring to idle.
        • charm5496
          • 2387
          Check connectors J229, J230, replace Duplex Horizontal Registration Motor M16. May also need Duplex Driver PCB and Duplex Horizontal Registration Sensor PS31
          • ar6565
            • 94
            Thanks all.
            (charm5496) got it. The problem was at M16 it isn't connected.
            • ar6565
              • 94
              Victor_v
              what do you mean "at first to press a door"
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5018
                Victor_v
                He mean open the front door.
                • victor_v
                  • 71
                  Victor_v
                  I mean: to press a door (a hand), then turn iR on..
                  There was a similar problem, specific, with the micro-switch of a front door. The message at the display was just the same...
                  • ar6565
                    • 94
                    Thanks for explanation
