Canon IR 4570 White copy
  • copyalbania
    • Aug 2009
    • 165
    Hello my friends,
    I have for service a Canon IR 4570 and yesterday they called me that the copier makes white copies.... i went there and the toner was full, i made some calibration and after that i pulled out the laser unit and put back in and i closed the copiers and everything worked ok.The copies were of very good quality!!!
    But they also called again this morning the same problem happened....
    Can anyone advise what is causing this strange problem??
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    For start check all connectors on controller box and DC controller PCB.
    • copyalbania
      • Aug 2009
      • 165
      ok thanks... i will see if i can work it out....
      but i haven't found any disconnected cable.
      I AM WONDERING IF ANYONE HAS ENCOUNTER THIS KIND OF PROBLEM!!!
      • wil chow
        Is it the same machine that have error E100 ?
        • copyalbania
          • Aug 2009
          • 165
          yes it is the same one
          • Tec.Inf.Mec
            • Jan 2011
            • 8
            u have a problem on link shutter
            • Canuck
              Tech Specialist
              • 1713
              What about prints? Check reg ground clips. If its giving laser errors, also reseat connectors at laser driver pcb on laser assembly.
