ir6570
  • universaltvm
    • May 2010
    • 52
    [Error Code] ir6570
    hi guys, i have a canon ir6570 and it is showing the error code 824-0001, what should i do , any one help plz
  • gensys
    • Jan 2011
    • 323
    Check FM2 primary charging cooling fan cools the primary charging assembly and the cleaner yes (24/12 V)
    any one help YOU
    The Road will be Mastered by >>> the Going...
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      any one help YOU
      Michael Buble.....nice...
      • teckat
        • 16083
        • gensys
          • Jan 2011
          • 323
          Hi teckat!!!!
          Tell to me please....
          What difference between iR 6570 and ir5570
          • bineshpaul
            • Jul 2010
            • 43
            re: error code
            check the primary charging cooling fan. check the connetors, clean the fan and try. Not yet solved then replaced it
            • teckat
              • 16083
              Hi teckat!!!!
              The Canon imageRUNNER 5570/6570 (Segment 4) are black & white multifunction copiers with speeds up to 55-cpm and 65-cpm. These MEAP (multifunctional EmbeddedApplication Platform) enabled devices feature the latest Canon Controller.
              Certain option software features are pre-installed on these units and to activate the software programs, the feature must be licensed through the LMS (License Management System) server. This replaces the need for additional hardware or dongles to activate new software.
              READ THIS PDF>> It Will explain in full>>>>>
              iR5570-6570 Intro TP05 099[1].pdf
              • gensys
                • Jan 2011
                • 323
                Thank you teckat. You can see that the Field Supervisor
                Good luck to YOU in all your undertakings................
