SDL login service (MEAP)
  • gensys
    • Jan 2011
    • 323
    [Misc] SDL login service (MEAP)
    Why? If SSO is set as the login service image Runner will take loger to become ready to scan...
    The Road will be Mastered by >>> the Going...
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    SDL is authenticating locally from the copiers HDD.
    SSO is authenticating from the Active Directory Server on your network via a security agent.
    I'm sure it takes longer communicating with the Active Directory Server, which I assume is encrypted communication, than it does communicating with the local HDD.
    Have you tried the newer hybrid SSO (SSO-H)? It doesn't use the security agent and is probably faster.
    • gensys
      • Jan 2011
      • 323
      Thanks D L P !!!!!!!!!!
      What kind encrypted communication uses in the HDD Canon?
