IR 4570 fonts problem
  • sundeep202
    • Oct 2010
    • 26
    [Misc] IR 4570 fonts problem
    whenever i want to print fonts other than English from internet the whole document didnt print correctly. some alphabets are printed like '????'. not all the alphabets but many of them randomly. plz he[IMG]file:///C:/Documents%20and%20Settings/Admin/Desktop/Save%20Scanned/2011_01_30/IMG_0003.jpg[/IMG]lp me
    also tell me how to submit related pic from my pc
    Last edited by sundeep202; 01-30-2011, 08:33 AM. Reason: i want to submit the pic of print bt i dont know how
  • sufie
    • Sep 2009
    • 10
    try chose your driver to pcl 6
    • ESA
      Is the Internet file a PDF? Do you have the correct language fonts loaded on you computer? If PDF you can chose print as image as a work around to missing fonts. Slower but successful; also as stated from Sufie I would try a different print driver as a test. Surprising there is many bugs in the drivers. Last point download the news driver available. Use the automatic install as it will update older versions for you. Hope this is helpful.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Open Printers and Faxes
        Right click on your printer and click Printing Preferences
        Go to the Quality tab
        Click Text, Details, go to Misc tab, uncheck Use Printer Fonts
        • sundeep202
          • Oct 2010
          • 26
          i unchecked the box but problem is still there
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            Sorry, I should have told you to Check the Download as Bit image also. If it is set for true type the printer will usually substitute its fonts anyway.
