canon iec3200 e20-0181
  • bcbs
    • Aug 2025
    [Error Code] canon iec3200 e20-0181
    I had replace the yellow drum and still having e20-0181 code after 200 or 300 copies.Does the ITB has anything to do? Any help?
  • teckat
    • 16083
    Check your PG 10 & PG 6Prints for IMAGE shifting
    It is possible the front door plastic door interlock for the SALT sensor shutter is broken or not in place, (see picture below). If the shutter is not actuated by the interlock,
    the SALT sensor will error out when trying to perform ATR measurement resulting in an E020.
    Sub codes will be related to yellow ATR measurement since it is the first color laid down on the ITB for ATR measurement.
    Check the front door interlock position
    Also make sure your ITB BELT is turning easily with no gear noise / remove cover right side/ power up printer to see if gradation image is being laid down/ Check the Image Position
    The fault E20-0181 occurs while ATR control is being executed
    • bcbs
      I ll check it all .thanks.
