IR 3570 problem
  • copyalbania
    • Aug 2009
    • 165
    IR 3570 problem
    Hello to everyone,
    i have a Canon Ir 3570 and i want to scan with it but in the main menu there is no scan option.
    I have other Canon IR 3570 and all of them in the main menu right to the copy option have scan option but in this one there is no such option.
    I have installed the scan driver and when i search for scanner in the network it finds my Canon ir 3570 but can not scan because i have to make the scanner online in order to scan.
    Is there any option to activate the scan function from the main menu??
    Please help.
  • kuby
    • Oct 2007
    • 1396
    Go to
    COPIER > OPTION > BODY
    then check
    W/SCNR Setting whether a scanner is present (Copy model)
    <Setting range>
    0: Printer model [Default]
    1: Model with scanner
    I think this is what you want.
    • Canuck
      Tech Specialist
      • 1713
      If you want pull scanning, you have to install network scan gear on your computer,launch the tool,discover scanners,etc. If you want push scanning,you have to install(and purchase) universal send.
      • manlyman07
        • Jan 2011
        • 8
        Hi mate
        Also check that in service mode level 2 that Copier- Option- User/Body?- UISCAN is set to one. This turns on the scan tab on the home screen of the copier.
        Let us know how you go
