iPC6000/ C6000VP/ C7000VP-Modifications of the Fixing Assemblies 53T and 16T Gears
  • teckat
    • 16083
    [Misc] iPC6000/ C6000VP/ C7000VP-Modifications of the Fixing Assemblies 53T and 16T Gears
    Modifications of the Fixing Assemblies 53T and 16T/31T Gears
    During the refresh operation, additional torque is generated upon the 53T and 16T/31T Gears when the Refresh Roller (FM3-1648-000) becomes engaged. This added torque may then cause the 53T and 16T/31T Gears to break, as well as cause the Small Gear Fixed Plate to become damaged.
    PRODUCTS AFFECTED / SERIAL NUMBERS AFFECTED:
    [see pdf] TP11-2.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Here comes one more new!
    ipc7000vp-102.pdf
