The first copy looks ok. But a closer look reveals the front part of the copy is
just a shade lighter than the back. After 6 copies, It is lighter all over and eventually
is un-usable.
The customer is using the same aftermarket toner as they alway have. When they
discovered the lightness of the copy they added toner even though the machine
did not ask for toner. I am using the precision roller drum and blade which have
always given me good performance in this model. But I know it could still be the
problem.
Here is what I did:
I recleaned the primary and transfer charge rollers, inspected the drum and
developer kiss and made sure there was deflection of the transfer roller when
it is against the drum. Ran the DPC program I forgot to run 10K copies ago
when I last replaced the drum. Cleaned the erase lamp and last mirror for the
laser.
I ran some test prints from the printer. The solid black looked ok but I was not
able to run successive black copy.
test print #4 the half tone shows the problem as lighter in the front of the
machine. Test type 2 & 3 did not show the problem.
I noticed a slight difference in the color of the drum from the front to the back.
The front looks just a slight shade lighter than the back.
I am leaning toward the drum.
Any comments would help
DR
is un-usable.
problem.
Here is what I did:
laser.
DR
