c3220 rdf jaming on low number of pages
  • persichini
    • Feb 2011
    • 7
    I'm having an issue with the rdf pulling multiple pages threw when you copying a small number. I can run 20 pages with no problem but when i try and run 4 it pulls 2 threw any ideas??
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Are you a tech?Do you check how many copies do you have with existing separation rollers on rdf?
    • persichini
      • Feb 2011
      • 7
      according to the counter in the service menu there are only 1320 on the feeder.
      • teckat
        • 16083
        Also Replace your Separation Pad
        DO NOT FOR GET TO PUT BACK THOSE DIP SWITCHES
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Get used to doing this procedure fairly often,,, the separation pad in this feeder never makes life in the counters. It is an ill conceived design, and to insure continued customer satisfaction, carry the pads with you and replace at the first hint of multifeeding...
          • Canuck
            Tech Specialist
            • 1713
            Make sure you transfer the little rollers from the old separation assy to the new one...rollers don't come with it.
            • persichini
              • Feb 2011
              • 7
              I'm waiting on a new pad to arrive... getting anything in the mail last week was a nightmare with our texas freak snow/ice storm. I went ahead and took the seperation pad out and cleaned it really good streached the spring and replaced it... work fine on friday but this morning first copy sucked 2 pages threw... i guess i'll just have to wait.
              • teckat
                • 16083
                Remember to clean the large rubber feed roller/ do not use alcohol on it
                If you have never taken out that roller pick-up unit---it can be a little tricky the first time
                with the sep pad unit out>
                Removing the separation roller
                Removal of the separation pad assembly)
                1) Lower the separation roller holder [1]
                and pull out the stopper [2].
                If you perform this procedure the dip switches are set as above, then re-install the sep pad unit/ & re-set dips back in position -stated in pad removal above
                • Canuck
                  Tech Specialist
                  • 1713
                  Shittiest doc feeder ever made
                  • vigour
                    • Aug 2010
                    • 1038
                    If your spring stretching skills fail, there is a modified spring available.fx
                    • teckat
                      • 16083
                      It's Not ROCKET SCIENCE to Stretch a Spring
