e840-001 on ir6570
  • y_us1982
    • Aug 2025
    e840-001 on ir6570
    i had this problem on field. i'd search the forum that E840 (fixing inlet sensor movement error). but i don't get where is the fixing inlet sensor. could somebody give me the picture of this thing so i can get to my customer to check it out.
  • kuby
    • Oct 2007
    • 1410
    E840 - 0001 is a shutter error. Check the connection of the connector of the shutter motor and the shutter HP sensor.
    • y_us1982
      i know it is a shutter error but could u give some picture or image which one is the shutter? sorry asking because i'm new with this model and dont have a service manual for this model.
      • dharani
        • 39
        1 .Check the connection of the connector of the shutter motor and the shutter HP sensor .
        2 .Check the mounting of the pin used to match the shutter gear phase of the fixing unit
        ( see descriptions under “point to Note when Mounting the fixing roller”)
        3. Replace the shutter HP sensor and the shutter motor.
        • charm5496
          • 2387
          Your shutter is item number 15 and sits on top of the holder unit #37. I would suggest acquiring a manual for this device. You are gonig to need it.
          • Canuck
            Tech Specialist
            • 1713
            Definitely get a manual. If you put the shutter assembly back together and its not properly syncronized..."snap,crackle pop...get some gears"
