Advance series default paper source
  • costd
    • Jan 2008
    • 409
    I do not have an Adv unit to "play" on - but trying to find what should have been an easy answer.
    Customer has an Adv 2030, and wants to change the DEFAULT paper source to drawer 3. They do not want to use Favorites - just want to walk up, select copy, and it pulls from drawer 3 rather than 1 (1 &2 have special paper).
  • charm5496
    • 2387
    turn your APS off for drawers 1 & 2.
    additional functions>LOGIN>function settings>common>paper feed settings>paper drawer auto selection. They can set it for all functions they use
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      what he said ^^
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Just another option.
        1. Set Select Paper to drawer 3
        2. Press the "Box" icon on the top right
        3. Press Change Default Settings.
        4. Press Register.
        • charm5496
          • 2387
          4. Press Register.
          Nice info!!! This is one I didn't know about
          • costd
            • Jan 2008
            • 409
            Thanks guys. I pulled a DOH! on APS - but DLP, how/where did you find that tid-bit? Maybe that was part of the "after test dump" I did. At my age it is hard enough to remember where I left my memory pills.
            Thanks again all.
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              I hate to admit this but it was from watching a salesman do a demo. Actually, he's probably the most knowledgeable salesman I've met in 15 years doing this.
              • charm5496
                • 2387
                I would like to shake that salesman's hand. I am truly impressed!!!
                • MrB
                  • Nov 2009
                  • 147
                  I had a few in one place
                  Where for some reason the paper was set to "Plain 2" on all trays
                  But also beware, Even if the trays are set to Plain 1, it can also still be set differently in printer settings
                  If it's set as Plain 2 in printer settings it will come up asking to load plain paper in the tray.
                  • Canuck
                    Tech Specialist
                    • 1713
                    Kinda like older irs....set to tray 3,additional functions,common settings,standard settings,store
                    • costd
                      • Jan 2008
                      • 409
                      Thanks again guys - I resolved the issue trying DLP's trick and it worked. Charm's answer also would have worked but thought I would give a new tip a try.
                      Thanks again.
