ir2525 fax issues
  • dqydj
    • Jun 2005
    • 65
    ir2525 fax issues
    anyone had any luck with the ir2525 faxing over a voice over IP connection.
    Tried everything I can think of but it just doesn't work. Customer has a brother
    mfp that sends and receives just fine over the VOIP connection.
    • 16083
    All Fax Capable imageRUNNER Models, All Laser Class Series Voice Over IP and Fax Communication.
    Will Canon Fax equipment work on a voice over IP circuit, (VoIP) ?
    Canon fax equipment will work on any circuit that meets the specification of a voice grade line.
    There are special considerations for fax communication over a VoIP circuit. The ITU, (International Telecommunications Union), has established a standard for this type of communication. It is known as the T.38 standard. If you connect your fax in a VoIP circuit and experience difficulty, you may want to make sure the circuit meets the T.38 standard.
    For a detailed description of the T.38 standard which governs fax communication on a VoIP circuit, please click the following link.
    T.38 - voip-info.org
    Canon USA
    Canon recommends (and is stated in the specs) a dedicated PSTN (public switched telephone network) connection - that is an actual, factual copper line from the phone company. Not a virtual-reality connection from the cable company.
    www.voip-info-org = navigate to the section entitled "Protocols used with VOIP" .
    http://www.voip-info.org/wiki/view/V...Providers+T.38
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      I had a similar question earlier and the general consensus was to turn off ECM
      Check it out here:
      http://www.copytechnet.com/forums/co...oip-faxes.html
