imageRUNNER counter codes
  • iRC
    Summer trainee!
    • 96
    Hello!
    At the service mode it's possible to choose what counters to display when counter check -key is pressed.
    So is there some sort of list where all of the counter codes are told? Or is there even any other counters besides the normal ones? (112, 113, 122, 123, 501, 301, 101)
    Thanks again for the help.
    -iRC
  • Van Steal
    • 177
    Originally posted by iRC
    Hello!
    -iRC
    RTFM
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Hello!
      -iRC
      Open service manual>service mode>option>copier>copier list>you can use counters from 101 to 958.
      • teckat
        • 16083
        101 Counter can not be changed/or moved/or erased
        • mtech
          • Mar 2007
          • 307
          You can change which counters to display. Go to copier>option>user
          • teckat
            • 16083
            Repeat>>>>>>>
            U CAN NOT CHANGE COUNTER 101 POSITION>>>>>>>>>>>>
            • iRC
              Summer trainee!
              • 96
              Yep, I know that. Just curious to know that what kind of different counters are there. But I'll check the SM when I got some spare time. I almost only use the SM to check out error codes. But nice to know that the codes are listed there.
              Teckat: I'm remembering that at least once I've seen a machine without 101 in the counter check -menu. I remember it because I added the 101 there afterwards. How could that be possible?
              -iRC
              • teckat
                • 16083
                Canon's Final Answer is=
                COUNTER 1
                Sets user mode screen software counter 1.
                Setting 101: Total 1 (Value at time of factory shipment/value after RAM clear: values 1.
                Fixed value that can’t be changed.)
                101 is locked in
                as TOTAL COUNTER ON ALL IMAGE RUNNERS
                U can not add it on~~~~~~~~~~~~~~~~~~~~~~
                At one time ,I worked in a Canon Engineering test office.
                If someone invents a way to remove that count total ,
                at least in USA/Canada=bottom line is -U can go to jail-
                Counters #2 to 6 can be changed
                <Software counter specifications>
                The numbers entered for software counters are classified as follows:
                100 to 199: Total 500 to 599: Scans
                200 to 299: Copies 600 to 699: Box prints
                300 to 399: Prints 700 to 799: Received prints
                400 to 499: Copies + prints 800 to 899: Report prints
                • iRC
                  Summer trainee!
                  • 96
                  That's really really odd. Well, I might remember wrong then. I guess I need to check that out. I'll report back, when I know more.
