Hello all.
Did some searching first but could not find the answer.
Trying to install the network card in an IR2200.
Upgraded firmware to 45.01 using SST 3.22 and standard parallel cable with xp.
Completes successfully but when I power cycle the copier it starts to boot then shows error E602 - 0004.
Tried a few different hard drives with the same result.
Going back to the original hard drive with old firmware. I can access the LAN web based Remote UI. That works fine.
Any suggestions would be very much appreciated.
