IR5055 Error Code E040-010
  • vishop
    • Jan 2011
    • 220
    Hello guys,
    Need to know this error code details for this machine. Its not in our manual
  • teckat
    • 16092
    Originally posted by vishop
    Hello guys,
    are u sure that is the correct read out on panel E040 ??
    only seen that code on a CLC for cassette/mf lifter motors
    also may have been for the CLC deck also-
    • vishop
      • Jan 2011
      • 220
      yes teckat, its confirmed code, E040 for IR5055n, thats what my fellow technician told me, its not found in the service manual for IR5055/5075.. Anyway he also doubt that part(lifter motor), and going to check for it...
      Thank you teckat, will give you feedback as to what the outcome is...
      • charm5496
        • 2387
        I have also seen this error on the IRC-5180 series, but it had to do with the fixing/feeder sensor and switch assembly which does not apply to this model. I can't find anything for this error pertaining to the error you are having.
        • teckat
          • 16092
          are u sure it is not an ALARM CODE ?? if so , it would be 04-0001 for deck lifter m
          when did this tech note the code ??
          is the printer up or down ??
          what are the other Error codes shown in log ?
          does printer heat up ?
          • teckat
            • 16092
            If it is an Alarm Code 040011
            Alarm is for right deck retry to pick up failure.
            • vishop
              • Jan 2011
              • 220
              The error code noted on the screen is read as E0004000-01000. Anybody can interpret this and where does this error point to?
              A fellow tech says its read as E040 while another one says its E400.
              • Gamut
                • Jul 2008
                • 216
                Are you sure it's not E004, get him to check fuser then try error clear, and report back.
                • vishop
                  • Jan 2011
                  • 220
                  its not fuser problem.
                  • THUK
                    • Jul 2008
                    • 195
                    hi,you have a E400 code is it to do with the feeder DADF.
                    • teckat
                      • 16092
                      does the machine power up ??
                      if u do not have power up, it's not a E400 feeder code
                      Is your Feeder working ??
                      can u make a copy or a print ?
                      u need to provide what is functioning & what is not !!!!!!!!!!!
                      when did this code appear = after service/during service/ while printing ????
                      Never see a Error code displayed that way/ on the back end with five numbers
                      if for an E400
                      Power of printer/Re-seat the cable going from the ADF CONTROLLER to MEMORY PCB
                      If E400 is still present it has been found that replacing the ADF Controller or MEMORY PCB may be necessary.
                      for an E004- U can try to go in service mode to clear it (COPIER>FUNCTION>CLEAR>ERR)
                      power of /power on
                      where is this master tech ???? on phone or on site
                      take a picture of the control panel ERROR CODE and post it here
                      • vishop
                        • Jan 2011
                        • 220
                        solved!!! Feeder Problem... Thanks Guyz! Thanks teckat
                        • teckat
                          • 16092
                          Welcome
                          • Raoufselwaness
                            Expert
                            • Nov 2008
                            • 75
                            Re: IR5055 Error Code E040-010
                            Welcome
                            [ATTACH=CONFIG]8531[/ATTACH]
                            dear teckat
                            do you have ir5055 "family" service manual because i have this error "e400-100" and have solved
                            but there are alot to know about this m/c
                            thanks alot
                            raouf
