imagespress c1
  • shabaab
    • Aug 2025
    [Error Code] imagespress c1
    facing problem this erore code e000020 01a8
    plz help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    plz help.
    Check the yellow developer life.How many copies do you have?
    • zoraldinho
      • Mar 2008
      • 5015
      Also check:
      Description
      Since the ITB connecting shaft was not tightened after the process unit to which a weight and the developing assembly were mounted was set into the main
      body upon installation, yellow was displaced in both copying and printing. The degree of displacement worsen toward the trail edge.
      Field Remedy
      When the symptom occurs at test printing after re-mounting the process unit during installation or servicing, check to see if the ITB connecting shaft is
      loosened; if so, tighten it again and then perform a copy/print job.
      Note: When tightening the ITB connecting shaft [1], hold the drum fixing member [2] to prevent the idle rotation of the shaft.
