problem ccd ir5000
  • andreas182
    • Aug 2025
    [Electrical] problem ccd ir5000
    hy gues can you help me how to fix and service CCD pcb ir5000 please mail me.. eas182@yahoo.com
  • teckat
    • 16083
    what is the issue u need fixed ?? ERROR ?/ CQ ??
    / Points of Detection ?
    When Replacing the CCD/AP PCB
    Be sure to execute ‘CCD auto adjustment’ in service mode, and record the updated CCD
    adjustment data on the service label.
    1. CCD Auto AdjustmentCOPIER>FUNCTION>CCD> CCD-ADJ
    2. CCD Adjustment Data all items under COPIER>ADJUST>CCD
    COPIER/ADJUST>ADJ-XY>ADJ-Y (CCD read start position adjustment)
    It is used to adjust the parameter used determining the read start position in main scanning direction.
    Range: 0 to 400 (A change by ‘12’ results in a shift of 1 mm.)
    COPIER>FUNCTION>CCD>CCD-ADJ (shading auto adjustment)
    Execute the mode after replacing the CCD unit, scanning lamp, reader controller PCB, or standard white plate.
    COPIER>ADJUST>CCD>PPR (density data of standard white paper)
    COPIER>ADJUST>CCD>PLT (density data of standard white plate)
    COPIER>AJDUST>CCD>GAIN-E/O (gain adjustment input of CCD
    output)
    COPIER>ADJUST>CCD>OFST-E/O (offset adjustment input of CCD
    output)
    COPIER>ADJUST>CCD>SH_RATIO (white level ratio data of standard white plate and standard white paper during shading correction)
    If a faulty image is generated after executing shading auto adjustment, enter
    the parameter values indicated on the service label.
    When Replacing the CCD Unit
    1) Replace the CCD unit.
    After assembling the machine, connect the power plug to the power outlet, and turn on
    the main power switch.
    Execute the following modes: CCD auto adjustment:
    COPIER>FUNCTION>CCD>CCD-ADJ CCD edge gain correction position auto adjustment:
    COPIER>FUNCTION>CCD>EGGN-POS
    When the following data is updated (automatically), record them on the service label:
    COPIER>ADJUST>CCD>all items
